Typically when I get this error it goes back to a constaint created by
IV during part creation or insertion (as froma library). What I do is
to delete any existing constraints, and add just the ones you require.
Off the top of my head, I can't remember this ever not getting rid of
this error.
Good luck.
Chris
Pelus wrote:
> Hi!
> I have problems using insert constraint. See attached picture. If i use
> insert as the leftmost picture shows, i get an error: "Constraint is
> inconsistent with another and must be edited, deleted or suppresed." But
> if i use mate constraint twice, as these two other pictures shows no
> errors will occur! Can anyone tell me why? The value (82 mm or -18 mm)
> don't change the situtation. Both parts has straight cut, so both ends
> are perpendicularly to cylinder surface. Does insert use different
> tolerances than mate? This assembly were originally done with INV6, but
> i copied it with DA to new one. Now i encountered this problem. There
> have been many similar cases before also, so what is up? -- Alpo
