Solved by sam_m. Go to Solution.
without an image or a file I'm not 100% sure what you're after. But, if you just need the existing surfaces to "grow" a little to let them intersect then you could try the "extend" command (tucked away in the Surface drop-down) or the Patch command to fill any voids?
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
