You are doing this by using the pulldown menu in the browser to get to the
Content library and then drilling down to the right part? do you see the
picture of the part? there should be some dropdown lists to set the
parameters, and then it is normal iDrop type of stuff.
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"l_bennett" wrote in message
news:f1203f0.-1@WebX.maYIadrTaRb...
> I'm trying to place a library bearing into my assembly but failed
miserably. I've looked through the help menu and it states you need to
specify the parameters first before you can insert it. The problem is where
do you change these parameters. There are no edit boxes or pull down menus
as it states in the help file. Can anyone help as it is driving me crazy!!!
> Thanks in advance
> Lee
