Inventor General Discussion
Active Member
Ibanezmike
Message 1 of 4 (157 Views)
Accepted Solution
Problems with frame generator
157 Views, 3 Replies
02-10-2014 11:24 PM
I have made  a frame assembly for a caravan but I am only able to insert members to one side of the caravan. I have made an extrusion from one side of the frame and made a solid with a clear material. I made a new sketch on the other side of the caravan with lines everywhere I want the frame members to go but I am not able to insert the members onto the lines. Any help would be awesome, Thanks -Mike
Distinguished Mentor
JoAnn_Hogan
Message 2 of 4 (144 Views)
Re: Problems with frame generator
02-11-2014 12:41 AM in reply to: Ibanezmike
Hi there,
First of all your sketch should ALWAYS be fully constrained. Your sketch was a mess and thats why it didnt want to work. Do not use Automatic dimensions and constrains.
I have copied your geometry, fixed all the problems and made sure everything is fully constraint. Please see the attachement. Also when you want to use your Frame generator you need to have the sketch as a seperate part, otherwise it wont work either. Have a look at the sketch of test part and the assembly
Please let me know if this helps.
Jo (P.S follow me on twitter @JoAnn_Hogan)
If this post solved your issue please mark as solved and Kudos are always welcome =)
AutoCAD Certified Professional 2014 / Inventor Certified Professional 2014
Active Member
Ibanezmike
Message 3 of 4 (117 Views)
02-12-2014 04:13 AM in reply to: Ibanezmike
Thanks heaps for the help Jo. I had the constraints turned off, so thats why my sketches were such a mess. I will have to look into constraints a little more I think.
JoAnn_Hogan
Message 4 of 4 (111 Views)
02-12-2014 05:10 AM in reply to: Ibanezmike
This would be a great place to start. http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-EC368AD8-21A6-4207-85B7-E757DDB74272
I am glad I could help
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
