Do you use consistent names for your library's between projects?
There is a good tutorial on project paths that you can find by clicking on the Point A
icon, and the select "Articles" Also Drew has some good info at www.mymcad.com
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Ade"
wrote in message
news:5EEE4B839ABC8C203C8038594548CBAB@in.WebX.maYIadrTaRb...
> Hello There!
> I'm having problems with some iparts and Project paths. The ipart are some
> fixings that I have downloaded from cbliss.com. The directory where the
> ipart is located is specified in the project paths and the directory where
> the ipt created by the ipart is located is specified in the project paths.
> When opening up the iam file I am told that the paths do not exist in the
> project even though Inventor had already navigated to them and all I have to
> do is click on OK. Are my problems occuring because my ipart and the created
> ipt are in different directories?. Please help as this is driving me nuts
> and it's fouling up our document management system.
> Thanks
> Adrian Danvers
> CAD Engineer
> Isoma Conveyors Ltd
> Derbyshire
> England
