Hello all,
After making some modifications to a pressure vessel I did a few weeks ago I got this error message (see attached pic). Does anyone know what this is and/or how I might try to rectify this situation? To be honest I have had some issues with this model ever since converting it to a weldment. I can't Pack N Go this model to attach here because I can't save it now (unless someone else has a way around this).
Thanks for the help.
I just closed the document, clicked "yes" to save the changes, the above error message came up again, I clicked OK. It closed the file. I then opened the file again, it told me there were changes to the file and asked if I wanted to update the model, I said yes and got this error message about memory availability (see attached). I am so confused.
Try opening your part files and do Rebuild All on them.
Did you have enough resources (RAM) available at the time of save/load?
Lucia Casu
Inventor Development
Thanks John. Although the rebuild all on each part did not fix the issue it highlighted where the issue was. I still have no idea what was causing my fully-constrained sketch to behave in that manner but I just remodeled that part and replaced it in the assembly. Then everything worked.
And thank you Lucia for your attention to the matter but I would assume with 16 gigs of RAM that I would have enough to do whatever I needed.
