Inventor Forum
Problem with camera animation
6 REPLIES 6
269 Views, 6 Replies
I'm trying to make an animation for work, by animating a camera along a path. Should be simple enough, except it rotates through 180 degrees, which I don't want it to do. Any help would be great,
Andy
Inventor 2009
6 REPLIES 6
any ideas???
markus.lahtinen
Hi, I was happy to see your post because
I strugled with the same problem but cuoldnt exactly understand what causes it.
I found out that when camera and targer paths are not coliear ( or gets wery close eachother)
it flips camera like in your video.
I simply gave up after not finding help to it .
markus
mflayler2
Can you post your dataset? If it is too large you can contact me on my blog and I can give you instructions to my ftp site. I have some time today and tomarrow I can look at it.
Mark Flayler
Application Engineer - Manufacturing Solutions Division
Blog: www.rand.com/imaginit/manufacturingBlog
Partner Certified, Inventor Certified Expert
Instructor - ATC
AIP 2009 SP1 Bonus Tools
Dell m4300, Core 2 Duo T8300, 4 GB Ram/3GB switch
Quadro FX 360M; Driver 6.14.11.7575
Windows XP SP3, Zune Theme
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
a5100274 ha scritto:
> Hi, I'm trying to make an animation for work, by animating a camera
> degrees, which I don't want it to do. Any help would be great, Thanks
> Andy Inventor 2009
I'm ignorant about camera animation in Inventor, but I wonder if it
could have something to do with the direction of the local z axis of the
curve (where x is tangent and y is directed towards the centre of
curvature)...
AIS 11 SP4
Pentium 4 3 GHz - 2 GB RAM
NVIDIA Quadro 330 6.14.10.9136
markus.lahtinen
Hi Mark
Thanks for your response.Attached my unsuccesfull testing of camera motion.
I just couldnt figure out why camera rotates as it does.
Im eager to hear how to correct my workflow.
Markus
IV2009sp1
Hi Andy,
Thanks for your feedback.
This is a known issue. In studio, camera vector is defined using the direction of axis Y. Therefore, in a camera path animation, camera will rotate if its vetctor is parallel to axis Y.
Brenda Chen-Autodesk
