Inventor Forum
Problem in following the training guide book.
6 REPLIES 6
tonyaimer
348 Views, 6 Replies
Greetings.
I am teaching myself Inv 2011 from the Waguespack / Tremblay book for Inv 2011 and have got stuck on page 330.
I have loaded mi_8a_001.iam as instructed.
They tell me to click on the Assemble tab and then select the drop down on the productibvity panel and select degree of freedom analysis.
I cant find a productivity panel on the ribbon or a degree of freedom analysis button anywhere.
Can someone steer me in the right direction here please. Maybe the book is referring to an earlier version of inventor which had these things as stated, and these options have been relocated?
Thanks in anticipation
Tony Aimer
6 REPLIES 6
japike
in reply to: tonyaimer
If you can't find the Productivity panel on the Assemble tab, then try right clicking on the ribbon, hover over show panels and make sure Productivity is checked.
Another way to find a command quickly is click on the big I (upper left corner) and, in the search dialog (top most part of the drop down) start typing the command (in this case "degree of freedom analysis") and within a few characters you'll get a match.
Peace,
Jeff
Inventor 2022
Hi tonyaimer,
Thanks for supporting the book. In addtion to the previous suggestion to use the search tool (which is nice tip also), you can find the Productivity panel as shown here:
And the Degrees of Freedom tool fro the fly out as shown:
If you don't see the Productivity panel you might have it turned off. You can enable it by right-clicking on any panel and then selecting it as shown:
I hope this helps.
Curtis
tonyaimer
Thanks for the tip of right clicking and checking that productivity is turned on.
It did not work as my panels list does not include 'productivity'
All I have is      Component
                        Position
                        Manage
                        ipart/Assembly
                        Work features
                        Convert
                        Measure
Curtis - I see your screen dump shows you have the pro version of Inventor.
I only have the version below that - I forget what it is called but I dont have simulation etc.
Could this be the problem?  I would not have thought so
regards
Tony Aimer
tonyaimer
in reply to: japike
Thanks for the tip but see my reply to curtis
I tried typing 'degrees of freedom ' into the box as you suggested but I only got how to
show the degreees of freedom using the button in 'view'.
It did not offer me degrees of freedo analysis.
I have the invenotr 11 version 1 down from Pro and this may be my problem?
Regards
Tony
Hi tonyaimer,
Your version should have these tools as well.
Try this:
Go to the Tools tab and click the Addins button.
In the list look for an add in called: Assembly Bonus Tools
If it's listed but not loaded, then load it.
If it's not listed, then you might need to do a Repair to your Inventor install.
I hope this helps.
Curtis
tonyaimer
Voila and the problem is solved!
Thanks all round.
Now I am going to get my nose back into the book again.
Regards
Tony Aimer
Johannesburg
