Inventor Forum
Problem - Import DWG to Inventor
14 REPLIES 14
Message 1 of 15
LEOALEX
2430 Views, 14 Replies
I,
Please, i need importa dwg to inventor for create a solid.
The problem is when a import the file, in the "layers and objects import options" , inventor don't show me some layers present in the dwg.
It is a problem?? or i need configurate anything???
14 REPLIES 14
Message 2 of 15
JDMather
in reply to: LEOALEX
Something isn't right here.
Attach the dwg file here to see if others can reproduce the behavior.
Message 3 of 15
I've had that happen and I THINK (I can't recall for sure) that unchecking the ALL checkbox was the trick. I may be wrong though.
Message 4 of 15
LEOALEX
desable the option "all", but the problem continue. I used drawing of the folder sample of mechanical. Attch have one sample.
Message 5 of 15
JDMather
Worked fine here.
What version of Inventor and AutoCAD do you have installed?
Message 6 of 15
LEOALEX
in reply to: JDMather
Autodesk Inventor Professional 2011 SP1. Mechanical 2011. 😕
Message 7 of 15
JDMather
Does the problem persist after rebooting the computer?
Message 8 of 15
LEOALEX
yes, the problem is old. I know if have hotfix for the problem?
Message 9 of 15
LEOALEX
yes, the problem is old. I don't know if have hotfix for the problem?
Message 10 of 15
I know I had this issue, and I tried several things, I just don't recall what worked.
Some things to try:
  • If running on Windows 7, close Inventor, and then restart it by rightclicking the shortcut and picking "run as administrator"
  • go to the tools tab and click the Add Ins button and make sure the DWG translator is loaded
Message 11 of 15
yannick3
Hi
I think your dwg trueview installation is corrupted try to uninstall/reinstall it
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Message 12 of 15
no solution, but here is the same problem:
http://forums.autodesk.com/t5/Autodesk-Inventor/importing-DWG-files-problem/m-p/2725569/highlight/tr...
also a couple of things to try here:
http://forums.autodesk.com/t5/Autodesk-Inventor/Importing-AutoCAD-DWG-to-Inventor/m-p/2543467/highli...
including just copying the geometry in AutoCAD and Pasting into Inventor.
Message 13 of 15
LEOALEX
I reinstall dgwtrue view, bat AIP show me a error.
I attech the picture of the error!!
the problem continue... 😕
Message 14 of 15
yannick3
Hi
Have uninstall before
uninstall all dwg trueview release before fresh install you can download it
http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&siteID=123112
i've seen this issue before and the problem is dwg trueview corrupted.
Yannick Verreault
INV PRO 2015
MS Office 2007
WD caviar black 1To
Message 15 of 15
I have litle bit difrent problem.
When i try import dwg files to inventor, won't show popup window with "setings" and nothing's more happen (see video on link:http://www.youtube.com/watch?v=tHyfQ8kDN7s&feature=youtu.be ). But when i try open dwg files everything works fine. Have anyone any solution for this issue?
