Inventor Forum
Print the excluded sheet
2 REPLIES 2
av8r
223 Views, 2 Replies
How do you print the sheet that is "excluded from count"? The excluded from printing box is NOT checked and it still does not print. I even tried selecting the "print excluded sheet" option in the print dialog box. This did not make any difference.
Has anyone had this problem?
Kevin
2 REPLIES 2
MechMan_
in reply to: av8r
I haven't seen this problem before. Try copying the sheet and paste it into a new IDW. If you can get it to print there then copy that sheet back into the original IDW. If that doesn't work then play with the copy/paste method of moving your sheet/view info until you get something to work.
Good luck.
MechMan
av8r
in reply to: av8r
I finally figured out that if you activate the excluded sheet and print the "current sheet" it will print. The larger question is, it appears that when the sheet is excluded from the count is is alos excluded from printing.
I wonder if this is a bug or Adesk wanted it this way?
If this is by design then what is the excluded from print option for?
Kevin
