Inventor Forum
Post your "One Button"!
18 REPLIES 18
Message 1 of 19
1062 Views, 18 Replies
As an Inventor user, what's that one button you'd love to use to make life soooo much easier when using Inventor?
Here's one to get things started;
So what's that one button that you've been wanting for ever? Post it here!
Tags (1)
18 REPLIES 18
Message 2 of 19
blair
"Save"
the more I save, the more stable IV is.
When working with large assemblies, the "Re-Order" ipt's within the browser window to be sorted in Part-Number sequence.
Waiting for the "Control ^C" button to halt a command.
Delta Tau Chi ΔΤΧ
Message 3 of 19
cbenner
in reply to: blair
Message 4 of 19
jletcher
in reply to: cbenner
No that would be easy just make it a history undo button like excel.. Easy
Message 6 of 19
jletcher
Oh lol....
Message 7 of 19
MSengr
in reply to: blair
I agree with blair, a button to sort items in the browser pane in part number sequence would be awesome. I use a macro to do this currently, but it is limited by the fact that you can't move component patterns within the browser. It would also be nice to be able to sort items in my .ipt broswer pane as well.
Message 8 of 19
stephen.wood-davies
in reply to: blair
Try this peice of iLogic code.......works a treat in ordering parts in an assembly to be numerical and alphabetical....
Message 9 of 19
This is good. I believe it's using the same "AlphaSortComponents" that I'm using, but this is a little cleaner than mine. Unfortunately, it still fails for me when component patterns are present in the browser pane.
Message 10 of 19
blair
I guess I should have been clearer, I do use the "Sort" button within the Productivity Panel alot. I like to keep my items within a IAM file sorted in the browser alpha-numerically. It's much easier to find items.
Still waiting for the "Easy" button!
Delta Tau Chi ΔΤΧ
Message 11 of 19
LT.Rusty
in reply to: blair
This is my one button ...
Rusty
Message 12 of 19
stevec781
in reply to: LT.Rusty
Seconded - would really like a button to Suspend error reporting
So annoying when I am fixing errors to have to constantly dismiss the error messages.  I know I have errors that's why I am fixing them !!!!  Or maybe change the Accept button in that message to 'Yes you told me already'
Message 13 of 19
MikahB
Thirded for Rusty's suggestion.
Mikah Barnett
All Angles Design
Product Design Suite Ultimate 2014
Windows 7 Professional x64
Intel i7-3770k @ 4.5GHz
32GB DDR3-2400 RAM
GeForce GTX 670 4GB
Message 14 of 19
Mark_Wigan
in reply to: MikahB
fourth for rusty error reporting button...
maybe if we tick "don,t tell me again unless i ask you to", the red cross turns to grey cross. That way we can track our progress if we are working on a large assembly.
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
Message 15 of 19
One button for "Clash check" for entire model.
That would be nice
Message 16 of 19
jletcher
Message 17 of 19
blair
You mean this error:
Delta Tau Chi ΔΤΧ
Message 18 of 19
andrewiv
They actually have that button.  It's located in the application options under the  prompts tab.
Andrew In’t Veld
Designer
Message 19 of 19
LT.Rusty
in reply to: andrewiv
Doesn't hide dimension broken dimensions problems, or at least not on a consistent basis.  That's just about the only error message that you can't suppress.
Rusty
