I'm sure this is wishful thinking but is there any way to control which areas of my part or assembly that I want to use the View Break on? Currently I'm not aware of any options. It wants to break through the entire assembly or part view.
Basically I have a coworker who designs his electrical harnesses in Inventor. Some of the wiring branches off the main harness are longer than others and he would like to break only that specific branch of wiring, not the entire horizontal or vertical area of the view.
Please see my simple example I made which helps illustrate what I'm asking.
Thanks in advance for any suggestions or solutions to his issue.
Yes, there is a simple fix, move it to the right past the other lines :). Sorry, but I do not believe Inventor will do what you want it to do in this situation, although it is possible someone knows a work around.
