I've got some IGES files, which I want to place into an assembly, and then create a drawing of the assembly.
If I open the IGES and place it in a drawing it works. If I create an assembly, place the same part, and then try and put the assembly into the drawing it doesn't work.
Attached is the IGES file. I'm using Inventor 2011.
Solved by markc-uk. Go to Solution.
Solved by JDMather. Go to Solution.
Convert to a solid
or
right click and select Include Surfaces in the drawing file of the assembly.
Nice, that gets me a drawing!
However, it only has external surfaces (using more complex parts than in previous uploaded file). Sorry if this us unrelated, still new to this.
What version of Inventor are you using?
I will try to post a pdf later that explains how to convert surface bodies to solids.
I'm using 2011.
A guide would be very useful. I'm learning about breakout views at the moment, which might help... but would really appreciate that pdf if you have it lying around. Thanks!
That's a really nice, simple 'neutral' file to cut your teeth on. Using my limited experience, I managed to translate your .igs file very easily into a simple solid .ipt in about a minute.
I've recorded my process using snagit but it's a big file (63Mb) so I don't think I'll be able to post it on here. I can email it or upload it somewhere if you want to take a look?
All my neutral file conversion skills have been learned from a presentation that JD did at AU. I bought the tutorial and often refer back to it!!
Erm, possibly....I'll speak to my social media consultant (12 year old son) when I get in from work.
If all goes well, it'll be on youtube in about an hour!!
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
http://home.pct.edu/~jmather/AU2008/ML205-1P-Dataset.zip
These are a little old - but works the same way in your release.
There is now something called Repair Environment in addition or rather than Construction Environment. 2010/2011/2012/2013
OK, so the video is now on YouTube, here's the url
It look a bit small on screen but hopefully it will give you an idea. The main steps are: click >options before opening the file just to confirm your settings. Unfortunately, there are no hard and fast rules about the options to set in here and on more complex files it will invovlve trial and error. Then click >open. RMB on the composite in the browser and click >copy to construction environment. Drag the End Of Part marker above the composite feature. RMB on the EOP marker and click>delete all features below marker. RMB on the construction folder and click >edit construction. Expand out the folder to see what it contains. RMB on the surfaces node and click >unstitch. RMB on the surfaces node and click>quality check>examine. It passes - good news! RMB on the surfaces node and click >stitch. Notice it stitches up cleanly into a solid. Now RMB on the solid and >copy object. Select solid to copy the new solid from the Construction Environment to the part environment. RMB and click>exit construction environment. You're back in the usual part editing environment. RMB on the construction folder and click >delete. Pat yourself on the back as you've translated your first iges file!
JD - I'm sure there might be some comments or feedback but I think I've covered most of it?
Perfect, this is exactly what I needed! Thanks very much indeed, and thanks to your son too!
