Inventor Forum
Platform grating help needed.
5 REPLIES 5
Jefkee
2651 Views, 5 Replies
I'm looking for a way to make an appearance for grating of a platform.
But i don't have a clue. The inventor appearance expanded metal 02 looks a little bit to what i need but i need 30mmx30mm checkers and these are more like 3x3..
How can i make them larger? or does someone have a texture that i can use?
Thanks.
Inventor 2013
5 REPLIES 5
JoAnn_Hogan
in reply to: Jefkee
Hi There,
Ok so first of all, Please have a look at my screen shot while reading the steps:
  1. Select the "Apearance" command
  2. Right Click on the material you would like to change and select "Edit"
  3. Click on the image as shown in the attachment
  4. In the scale drop down change the "Sample Size"
PS I would duplicate Expanded Metal 02 and name it "Test" and then go change the properties
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
mdavis22569
in reply to: Jefkee
What we also do is: Make the plate the size you need it to be... We cut out a sq/rectangle area and then pattern it to make it look like grating. You can see thru it etc as need. I attached a file..not sure if it'll come thru though Mike
Mike Davis
graemev
in reply to: JoAnn_Hogan
I have found that for the expanded metals one needs to adjust the image in the "Cutouts" section to have an appropriate effect on the appearance.
Jefkee
in reply to: graemev
Yes, i noticed it to when adjusting the size.
Always adjust the cutout scale too!
Thanks for the help!
Inventor 2013
JoAnn_Hogan
in reply to: mdavis22569
Hi Michael,
Only problem I have with your suggestion is it will make your part extremely big/heavy and if your PC is not strong enough it will crash. The only time I will do someting like that is when I actually want to get the correct mass. but for presentation perposes I would rather change the material as it is not making my part heavy
Jo - Ann
