I still get the pause zoom effect with a Qudro card; but only when using the
mouse wheel.
I since the wheel motion is almost more of a segmented "ratchet" motion, I
think the comp interprets each "click" of the wheel as a command.
So instead of using the zoom command-where the computer gets one command to
zoom and then it regens the image;
the computer is getting a command to zoom>then regen> but before it finishes
regening you spin the wheel to make it zoom again.
I think it just gets bogged down with a bunch of zoom commands while it is
trying to regen the image.
"Ben Ruppel" wrote in message
news:2F70F8BBDB3ED9F9A270BD77019276F9@in.WebX.maYIadrTaRb...
> Hi all, I'm still with IV5.3 and I wanted to know if IV7 still has this
> problem, or just if anyone else has seen it. My issue is difficult
> because I can't reproduce it by just opening Inventor and zooming around
> assemblies, but only after working on parts for a while. Inventor gets
> into this mode where whenever you try to zoom in or out beyond a certain
> threshold, there is a long pause of 2-3 seconds. This happens when I'm
> looking at a part up-close, or if I'm zooming very far out. In either
> case, there is a zoom level that causes a pause every time it is crossed.
> At first I thought it was my computer, a 1Ghz Athlon with 768 MB of ram
> and a Geforce2MX. But now I have a 2.4 Ghz P4 with a gig of ram and a
> Geforce 4 Ti 4200 with 128 megs of ram, and I still have the same
> problem. Could it be AGP swapping or video memory? I suspect that it
> could be Inventor changing the model detail depending on the view
> distance (LOD, level of detail changing is something I've read about).
