I'm on Inventor 2014 and when I create my circular pattern only one of the patterned holes is generated properly. There is a screenshot attached showing the problem holes. How do I fix this?
Solved by andrewiv. Go to Solution.
What happens if you drag the patterned holes to be the last feature in the browser? Does it still do it? I just don't know what those extrutions past the pattern are.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Is it safe to assume that these holes are through all going in both directions?
Can you post your part here in this thread?
Yes, I'll attach it. The only thing is that this is an inherited part so I might not be able to explain all of the decisions.
Change your creation method in the circular pattern to adjust and it works fine.
Andrew In’t Veld
Designer
I believe that when you use the identical method it keeps the same X-Y orientation of the feature that you're patterning. If you us the adjust method the feature rotates with the pattern.
Andrew In’t Veld
Designer
You'll need to double check your patterns, but this seemed to do it.
