Inventor Forum
Patterned thru holes leaving random bits of material behind.
8 REPLIES 8
Message 1 of 9
C.hickey
4649 Views, 8 Replies
I'm on Inventor 2014 and when I create my circular pattern only one of the patterned holes is generated properly. There is a screenshot attached showing the problem holes. How do I fix this?Patternproblem.PNG
Tags (3)
8 REPLIES 8
Message 2 of 9
Cadmanto
in reply to: C.hickey
What happens if you drag the patterned holes to be the last feature in the browser?  Does it still do it?  I just don't know what those extrutions past the pattern are.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 9
C.hickey
in reply to: Cadmanto
Those extrusions are unrelated cuts, it doesn't matter how I order the features it continues to be a problem.
Message 4 of 9
Cadmanto
Is it safe to assume that these holes are through all going in both directions?
Can you post your part here in this thread?
Best Regards,
Scott McFadden
Message 5 of 9
C.hickey
Yes, I'll attach it. The only thing is that this is an inherited part so I might not be able to explain all of the decisions.
Message 6 of 9
andrewiv
Change your creation method in the circular pattern to adjust and it works fine.
Andrew In’t Veld
Designer
Message 7 of 9
C.hickey
in reply to: andrewiv
Thank you, do you have a reason for why this would happen or was it a matter of toying around with it?
Message 8 of 9
andrewiv
I believe that when you use the identical method it keeps the same X-Y orientation of the feature that you're patterning.  If you us the adjust method the feature rotates with the pattern.
Andrew In’t Veld
Designer
Message 9 of 9
You'll need to double check your patterns, but this seemed to do it.
