I'm trying to pattern a subassembly onto a final assembly in Inventor, and it won't let me select the subassembly as a feature to be patterned. Is there a way to pattern a subassembly?
Solved by sysh. Go to Solution.
You should use the Pattern Component command on the assembly tab.
See the attached picture.
Thanks.
I was trying to use that, but it wasn't letting be select the subassembly as a feature to be patterned. I worked around it by right-clicking the subassembly in the model browser and selecting "Pattern Feature" from the right-click menu.
