Inventor Forum
Pattern visibility
6 REPLIES 6
750 Views, 6 Replies
Pattern visibility
Hi!
Can anybody explain to me why if in .iam view representation I make "component patterns" invisible, thay still on .idw drawing are visible, and worse part is that I can not turn off visibility manually in browser. Please see attach.
Thank you for your time 🙂
6 REPLIES 6
IgorMir
If I remember correctly - it is not enough just to turn the visibility of the pattern off. You have to expand the Pattern node and turn the visibility of the members off as well.
Igor.
Web: www.meqc.com.au
IgorMir
Better yet - make sure the drawing view is associative to the assembly. Here is a snap shot of what to look for.
Igor.
andrewiv
I've had this same issue with IV 2012 SP2.  They release a hotfix to correct the issue for 2012, but not sure about 2013.
Andrew In’t Veld
Designer
in reply to: IgorMir
Hi!
Thanks for answer. Yes - it is checked. I think it is by default always checked.
I do not want to expand pattern - it make assemblys list full of not useful information 😞
Спасибо за ответ! 🙂
IgorMir
Then it is probably a bug in the latest release of IV. In IV2010 it works - as expected.
Best Regards,
Igor.
P.S. Привет, Богдан! Рад помочь, если могу. Где Вы живёте? Для переписки на русском - можно использовать мой адрес со страницы. До связи!
innovatenate
I am not able to reproduce this using simple assembly that I have created to test this. I've uploaded my test files to this post. I'm think you may be in a Master View Representation or perhaps the View Representation is Locked
Please see the attachments for clarification.
Nathan Chandler
Principal Specialist
