I've been trying all sorts of methods to apply an image to a pattern of extrusions, but making a pattern of the extrusion (or solid) does not allow images/decals to be attached. Currently the only way I can have the image be applied to the top face of patterned extrusion is to create a new sketch, and inside of that sketch pattern the image with references to dimensions in the extrusion pattern.
Making a pattern of the solid, which includes the extrusion and decal, does not work either as only the extrusion is patterned. Is making a sketch with a referenced pattern really the only way to have patterned images in a single part file? I know I could make a single extrusion+image a part file, then pattern that in an assembly, but it just seems nonsensical.
Also, is there a reason why the pattern tool in sketch mode does not have the midplane feature (symmetric)?
Likewise i have a pipe with a decal.
When i pattern the pipe to form a train of pipes the decal does not pattern - it just stays on the first pipe only.
I also notice there doesn't seem to be a Suppress>If function for decals. What a shame! As this would allow me to switch between a variety of appropriate decal labels very easily.
Anyone know how to achieve this?
Any reason you aren't using iam files or iassemblies?
Or are you later on?
Seems like you are just using multi-body solid parts? Do you just have Inventor LT?
But in general.. The ability to pattern a decal in a part file is simply not supported.. You can add your request to the ideastation for possible addition in future versions of the software..
@DynamicObjects wrote:
Hi mcgyvr - as you have noticed the pipe-train part above is a multi-body solid part. It gets inserted into an assembly .iam at a later stage along with some of the kit that the pipe-train connects to.
Are you telling me that iassemblies offer the ability to pattern up a part containing a decal ? - i shall go investigate that. Thanks.
Your image and comments make me think that instead of making a multi-body solid that you might be better off using regular parts (probably iparts) and then iassemblies to be able to control the suppression of the decals/swap out different pipes/decals, etc...
But I'm only basing that of your image looking like it "could" be 3 pipes (well a single ipart that could have multiple versions based on the decal) and then swapping them out as needed in the iassembly..
But you cannot pattern a decal in a regular ipt or an ipart..
