Inventor Forum
Pattern of a image/decal
5 REPLIES 5
ben.walchli
1686 Views, 5 Replies
I've been trying all sorts of methods to apply an image to a pattern of extrusions, but making a pattern of the extrusion (or solid) does not allow images/decals to be attached. Currently the only way I can have the image be applied to the top face of patterned extrusion is to create a new sketch, and inside of that sketch pattern the image with references to dimensions in the extrusion pattern.
Making a pattern of the solid, which includes the extrusion and decal, does not work either as only the extrusion is patterned. Is making a sketch with a referenced pattern really the only way to have patterned images in a single part file? I know I could make a single extrusion+image a part file, then pattern that in an assembly, but it just seems nonsensical.
Also, is there a reason why the pattern tool in sketch mode does not have the midplane feature (symmetric)?
5 REPLIES 5
Likewise i have a pipe with a decal.
When i pattern the pipe to form a train of pipes the decal does not pattern - it just stays on the first pipe only.
I also notice there doesn't seem to be a Suppress>If function for decals.  What a shame! As this would allow me to switch between a variety of appropriate decal labels very easily.
Anyone know how to achieve this?
Atkins Consultants Ltd UK
+19,000 staff (M&E, Civils, Structural, Geotechnical, Environmental and more)
mcgyvr
in reply to: DynamicObjects
Any reason you aren't using iam files or iassemblies?
Or are you later on?
Seems like you are just using multi-body solid parts? Do you just have Inventor LT?
But in general.. The ability to pattern a decal in a part file is simply not supported.. You can add your request to the ideastation for possible addition in future versions of the software..
DynamicObjects
in reply to: mcgyvr
Hi mcgyvr - as you have noticed the pipe-train part above is a multi-body solid part. It gets inserted into an assembly .iam at a later stage along with some of the kit that the pipe-train connects to.
Are you telling me that iassemblies offer the ability to pattern up a part containing a decal ? - i shall go investigate that. Thanks.
mcgyvr
Your image and comments make me think that instead of making a multi-body solid that you might be better off using regular parts (probably iparts) and then iassemblies to be able to control the suppression of the decals/swap out different pipes/decals, etc...
But I'm only basing that of your image looking like it "could" be 3 pipes (well a single ipart that could have multiple versions based on the decal) and then swapping them out as needed in the iassembly..
But you cannot pattern a decal in a regular ipt or an ipart..
DynamicObjects
in reply to: mcgyvr
Thanks mcgyvr - that sounds like the solution. If I was the thread owner i'd mark that as the solution. 🙂
