If I place many parts than i create a new folder in the browser and place all parts in the new folder.
If I make a pattern of the same part that pattern I can not drag to the new folder where all the other equal parts are.
Well, I can right click on the pattern and then add to new folder but I can not click on existing folders so get a new folder is created where the pattern is placed.
Is it not possible to have a pattern to an existing folder to drag?
Solved by mpatchus. Go to Solution.
You should be able to drag the pattern into the folder, but I believe it has to be under the LAST item in the folder.
Expand the folder and try dragging the pattern under the last item (you should see a LINE appear below the last item as you drag the pattern into position).
Thanks, you must exactly click the right place.
It must be done exactly.
Some times i go over the new folder and it turns blue and then it works to.
Thanks again.
