Inventor Forum
Pattern in new folder
2 REPLIES 2
jostroopers
302 Views, 2 Replies
If I place many parts  than i create a new folder in the browser and place all parts in the new folder.
If I make a pattern of the same part that pattern I can not drag to the new folder where all the other equal parts are.
Well, I can right click on the pattern and then add to new folder but I can not click on existing folders so get a new folder is created where the pattern is placed.
Is it not possible to have a pattern to an existing folder to drag?
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
2 REPLIES 2
mpatchus
in reply to: jostroopers
You should be able to drag the pattern into the folder, but I believe it has to be under the LAST item in the folder.
Expand the folder and try dragging the pattern under the last item (you should see a LINE appear below the last item as you drag the pattern into position).
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
jostroopers
Thanks, you must exactly click the right place.
It must be done exactly.
Some times i go over the new folder and it turns blue and then it works to.
Thanks again.
Mvg Jos
