I am having trouble modeling with Path & Guide Rail Sweep. Please tell me what I am doing wrong. This error comes up when I click OK:
Hard to describe the shape in words; the picture should make sense though.
Profile is shaded on the right
The Path and Guide Rail are offset on prallel planes but otherwise identical.
Path is on top; Guide Rail is on bottom.
Both Path and Guide Rail pierce the profile.
Thank you for your help.
Solved by kmckenney. Go to Solution.
An ipt file would be easier to diagnose than a picture.
Found a solution. The sweep works when the profile is placed at the end of the path (file attached).
