Good morning,
When I zoom in on a drawing, certain parts of the drawing will just disappear. Dimensions, title block, text...it doesn't matter, its different every time. It's not all the time but when it happens it's frustrating. Try dimensioning a part that isn't visible! When I zoom out to a full page view it always returns. When I zoom in again, parts will disappear. See attached screen captures and you will see the same file at different moments. Any suggestions would be appreciated. Thanks.
Terry
Autodesk Inventor 2013
Windows 7 Professional
64 bit
16 GB RAM
Intel Core i5-2500 CPU @ 3.30 GHz
Have you checked that your video card meets the requirements, and if it does, do you have current drivers?
Did you try installing update 1 or 2? Out of curiosity what are your graphics set to in inventor?
We have the same problems at my company. 20 users reportet this problem. its on different hardware setup, and graphicdriveres.
Any solution to this issue?
We have just installed Inventor 2013 SP2, which didnt help on this problem.
BR
Mine does the same thing. I have a Quadro 4000k video with updated drivers... and it still does it!
Rodney
set tools..application options..hardware tab to "software graphics".. then restart Inventor.. Note: Inventor will be a bit slower but if the problem goes away then that typically lets you know your graphics card/driver is at fault..
Then try it set to "compatibility" and restart and see if that helps.. Then try performance..
I seem to remember numerous users with 4000k cards were having issues.. A search "might" yield what drivers they got that cleared it up might help..
