I double click to update my parts list, when I select apply or ok, the updates do not happen.
I have to close Inventor and re-open to see the changes.
Hello Erica,
Could you please describe your workflow in more detail? It would help to understand what kind of changes don't appear in the parts list.
Changes made in assembly should update parts list in drawing when drawing is opened or when switching between documents so drawing can react on changes made in assembly.
Oto Kaleja
I added parts to my assembly, went to my parts list and the new parts were at the bottom of the list (out of numerical order). I will double click on the list so that I can sort. It looks correct in the window, but when I click APPLY or OK it does not update. I need to close and reopen for the changes to take place.
Thanks for the update!
Unfortunately I was not able to reproduce the issue. Would it be possible to send some simple dataset which shows the issue at otoDOTkalejaATautodeskDOTcom ?
Oto
The error is in a very large assembly. Do you have a secure way that I can send this to you?
I have sent you a private message, plaese take a look.
Oto Kaleja
