Inventor Forum
Parts list column properties
4 REPLIES 4
soggys3
999 Views, 4 Replies
All,
I need to create a column in a partslist that reads IDENTIFYING NO. instead of the factory PART NUMBER title. When i create the new property in the column chooser dialog box how do i get inventor to pull the PART NUMBER from iprops over to the IDENTIFYING NO. column. Any help would be greatly appreciated!!
4 REPLIES 4
CCarreiras
in reply to: soggys3
Hi.
I think is easier to change the column title.
Go to "Manage" -> Styles editor and go to the part list field and change the name of Part Number column.
You can save this configuration as a template.
If you need some help, i can tell you better how to do it.
Regards.
CarlosC
solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
CCarreiras
Cadmanto
Then when the dialog window comes up. RC on the "Part Number" column and select BM.JPG
When this dialog window appears select the "Substitution" tab, select "Enable Value Substitution" and browse for the property you are looking for.
Good luck!!!  Smiley Happy
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
CCarreiras
in reply to: Cadmanto
Hi!
If you just want to change the title of the "Part Number" Column:
Go to tab Manage and select  "Styles Editor"
Then, just change the column title like the image below.
Now, Create a new Part List!!!
Regards.
CarlosC
CCarreiras
Cadmanto
in reply to: CCarreiras
Very nice Carlos.  Taking it even further then that, if this is to be saved to the styles (which makes sense long term), for template use, then the OP needs to know that he has to make the master project file read/write in order to save the styles.  Making sure that after they are saved, to change the MP back to RO.
Best Regards,
Scott McFadden
