When a parts list in an Inventor drawing is wrapped it always takes the bottom portion and kicks it to the left.
Is there a way to kick it to the right? So when you are looking at the BOM it reads such that item 1 is in the first group and not the second.
Solved by Curtis_Waguespack. Go to Solution.
Hi Cadmanto,
You can right-click on the parts list and choose Edit Parts List, then click the Table Layout button, then set the wrap direction. I don't recall a way to set this up in the Parts List style, but there might be one.
I hope this helps.
Curtis
Thanks Curtis.
That was almost too easy!!!
There is also a radio button set when placing the parts list. See graphic.
