wrote in message news:5920523@discussion.autodesk.com...
I have been given a project where I need to have (pressure vessel) parts,
sub-assemblies and main assemblies and their respective dwgs, created
'parametrically'. The basic goal is to have as little of .ipt files and many
different scenarios of .iam, .ipn (not necessary) & .idw (configurations)
Now, I am doing my groundwork to establish a solid foundation by looking
into,
1. Derived Part
2. iPart & iAssemblies
3. Skeletal Modeling
All the major parts will have spreadsheets with the possibility of
introducing tolerance as a parameter, which I am not even sure how INV will
behave or if its gonna snap at me.
I have alot of experience with iParts , I know a little bit about
iAssemblies, but never used derived part or skeletal modeling to acheive
these results.
I will appreciate any help, guideline(s), content or prior experience.
Thank you
__________________
Hello Irfan,
I have used Inventor to model pressure vessels and heat exchangers using
skeletal modeling, adaptive modeling and spreadsheet-driven techniques. It
can be done quite successfully, but initial setup of the project to account
for all the requirements is absolutely critical. It would be easy to start
down a worng road, only to find that some essential part of the project is
difficult or impossible to achieve without a considerable amount of
backtracking. In structuring an entire design project, that's a caveat with
the techniques you listed; they are advanced modeling practices that require
a strong understanding of their nuances from the outset. Understanding your
requirements well enough to suggest a specific course of action is probably
beyond the limitations of communicating via newsgroup. If the project is
important and time-critical, you would do well to hire a consultant to come
in and evaluate your situation, then help you develop a solution and train
you in the procedures. There are expenses involved in this, of course, but
not nearly as dire as the consequences of losing time to a faulty approach.
Cheers,
Walt
