Is it possible to make a sketch block parametric across multiple parts so that if I edit the sketch block in one part it will update in all of them? If not, is there a better way to do this? I have several parts that use similar geometry and want to control the identical geometry with a single sketch (or sketch block) if possible.
For example, all the parts are a rectangular shape with an arched top, and a specific cutout in the center. Some of the parts have additional holes, bosses, etc, but they all need to align across the arched top and all the specific cutouts need to line up through the assembly as they will be stacked. If a single sketch block isn't the solution what is the best parametric design practice in this situation?
Solved by JDMather. Go to Solution.
Sounds like a use for Derive Component (can be only sketch if desired, or the feature that is common accross all instances but subject to change across instances).
I found this old post as I was having the same problem.
I have a part created from a sketch which is linked to an excel table.
I have created a block out of the sketch in the hopes of retaining the parametric link with the excel table.
I then created a new part and attempted create a dervied part from the first part in order to bring in the block.
However when I try and select the elements of the derived part I want to derive, I can't select anything.
Ultimately I would like to have multiple instances of the same sketch driving several different parts and I would like these sketches to be controlled parametrically from the excel table. I am also trying to set myself up such that I don't continuously have to link the dimensions of each sketch with the excel table manually.
Hope this makes sense!
@anthonyhendrick wrote:
....I have created a block out of the sketch in the hopes of retaining the parametric link with the excel table...
This step wasn't needed.
In any case, attach your files here.
Ok, there have been a couple of developments.
1. The reason I could not derive anything from the first part is because it was the wrong file and it was empty for some inexplicable reason (so I deleted it).
2. I took your comment on board and created a sketch without converting it to a block and linked its' dimensions parametrically with the excel file. (this time using the correct file). However I found that it was hard to assign that derived sketch to a plane and therefore think it may be best to use a block as it seems easier to place.
Everything seems to be working just fine now.
