"Brian R. Iwaskewycz" <
href="mailto:biwaskewycz@patransformer.com">biwaskewycz@patransformer.com>
wrote in message
href="news:FB2C7FFC1883AB3DCF585366FA3B6A57@in.WebX.maYIadrTaRb">news:FB2C7FFC1883AB3DCF585366FA3......
Has anyone else ever tried to do this? For example, have an
extruded feature exist if parameter Show_Feature is 1, but not if it's
0? And I'm not talking about iParts - just standard parts.
I've got a little trick to make this work, but if this is already common
knowledge, I'm not going to create an example and explain it. Let me
know.
Brian R.
Iwaskewycz
Senior Mechanical Engineer
PA
Transformer Technology, Inc.
"Sean Dotson" <sean at sdotson dot com> wrote in message
href="news:6F04367E5BF44ADD1EC5FEC5D65A76FB@in.WebX.maYIadrTaRb">news:6F04367E5BF44ADD1EC5FEC5D65......
Other than using VBA I don't know of a
way...
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
wrote in message
href="news:FB2C7FFC1883AB3DCF585366FA3B6A57@in.WebX.maYIadrTaRb">news:FB2C7FFC1883AB3DCF585366F......
common knowledge, I'm not going to create an example and explain it.
Let me know.
Brian R.
Iwaskewycz
PA
wrote in message
href="news:C0CEDD638116E5EE6A4217A48AAE7335@in.WebX.maYIadrTaRb">news:C0CEDD638116E5EE6A4217A48AA......
Aha... perhaps I should create an example and post it to IVCF?
NO VBA IS NECESSARY.
href="news:6F04367E5BF44ADD1EC5FEC5D65A76FB@in.WebX.maYIadrTaRb">news:6F04367E5BF44ADD1EC5FEC5D......
way...
Sean Dotson, PE
Check the
Inventor FAQ for most common questions
wrote in message
href="news:FB2C7FFC1883AB3DCF585366FA3B6A57@in.WebX.maYIadrTaRb">news:FB2C7FFC1883AB3DCF58536......
Let me know.
Brian R.
Iwaskewycz
PA
wrote in message
way...
Sean Dotson, PE
Check the
wrote in message
Let me know.
Brian R.
Iwaskewycz
PA
wrote in message
way...
Sean Dotson, PE
Check the
wrote in message
Let me know.
Brian R.
Iwaskewycz
PA
wrote in message
know.
Brian R.
Iwaskewycz
PA
"Bob" <
href="mailto:bobschader@yahoo.com">bobschader@yahoo.com> wrote in
message
href="news:DFE7EBF730178D9118BF415E7BAC133B@in.WebX.maYIadrTaRb">news:DFE7EBF730178D9118BF415E7BA......
But I'll bet that Excel is required, as that is
the only way I know
of where you can put a conditional expression in
the parameter
table. Do you set the extrusion distance to zero
in this case?
Or you MIGHT be able to just multiply the
extrusion value by
Show_Feature, as anything times zero
should also be zero,
though I don't know how Inventor would
handle that.
Bob
wrote in message
href="news:C0CEDD638116E5EE6A4217A48AAE7335@in.WebX.maYIadrTaRb">news:C0CEDD638116E5EE6A4217A48......
href="news:6F04367E5BF44ADD1EC5FEC5D65A76FB@in.WebX.maYIadrTaRb">news:6F04367E5BF44ADD1EC5FEC......
way...
Sean Dotson, PE
Check the
wrote in message
href="news:FB2C7FFC1883AB3DCF585366FA3B6A57@in.WebX.maYIadrTaRb">news:FB2C7FFC1883AB3DCF585......
it. Let me know.
Brian R.
Iwaskewycz
PA
wrote in message
href="news:8C00C39D24F41192F515E14EC0D1CFCF@in.WebX.maYIadrTaRb">news:8C00C39D24F41192F515E14EC0D......
See post in IVCF... change parameter "Show_Relief" from 1 to 0 to
suppress the relief feature...
Again, NO VBA and NO EXCEL.
With all the talent out there in this NG, I find it really hard to
believe that I'm the first to come up with this...
wrote in message
Let me know.
Brian R.
Iwaskewycz
PA
wrote in message
know.
Brian R.
Iwaskewycz
PA
"Teun Ham" <
href="mailto:teunham@hotmail.com">teunham@hotmail.com> wrote in message
href="news:3750D013D19F7C4D8C10123F0D586B5A@in.WebX.maYIadrTaRb">news:3750D013D19F7C4D8C10123F0D5......
Hi Brian,
I have taken a look at your example, and for me
that's a known trick, but I am sure this new for quite some people
here
(You should zip your file and post to IVCF, now
it resides unzipped in Customization)
I do have one comment: never, never let a dim
become 0 with the possibility to be enlarged later on. That's a no-no in
Inventor. I know you "solved" this by having a temporarely block on both
sides, but you should avoid this in all cases.
Never-the-less it shows that feature "supression"
is possible without VB.
Cheers,
Teun
wrote in message
Let me know.
Brian R.
Iwaskewycz
PA
wrote in message
href="news:C588C2F811C31691E013C8A116009E95@in.WebX.maYIadrTaRb">news:C588C2F811C31691E013C8A1160......
Inventor will not allow you to extrude/revolve a feature by a zero
distance/angle.
"Bob" <
message
href="news:DFE7EBF730178D9118BF415E7BAC133B@in.WebX.maYIadrTaRb">news:DFE7EBF730178D9118BF415E7......
the only way I know
in the parameter
zero in this case?
extrusion value by
handle that.
Bob
wrote in message
href="news:C0CEDD638116E5EE6A4217A48AAE7335@in.WebX.maYIadrTaRb">news:C0CEDD638116E5EE6A4217A......
href="news:6F04367E5BF44ADD1EC5FEC5D65A76FB@in.WebX.maYIadrTaRb">news:6F04367E5BF44ADD1EC5F......
way...
Sean Dotson, PE
Check the
wrote in message
href="news:FB2C7FFC1883AB3DCF585366FA3B6A57@in.WebX.maYIadrTaRb">news:FB2C7FFC1883AB3DCF5......
it. Let me know.
Brian R.
Iwaskewycz
PA
"Bob" <
message
href="news:A9FACD8D83492CFDEBADB94F89D0830C@in.WebX.maYIadrTaRb">news:A9FACD8D83492CFDEBADB94F89D......
So you used the same concept to place the
extrusion somewhere outside the
part instead. What is the advantage of this over
just suppressing the features
in question? First it seems much harder to setup
and "get it right" as opposed
to just suppressing the features in the first
place. Plus there might be disadvantages
down the road, should Inventor decide to choke on
features outside the part,
as it has been prone to complaining about
features that do not change the number
of faces, etc. in the
past.
wrote in message
wrote in message
Let me know.
Brian R.
Iwaskewycz
PA
Sorry to burst your bubble but you weren't the
first...
