I'm having a really difficult time maintaining my parameters when making changes to the part I've made in the attachment. The control parameters for this part are:
-100 mm distance between 15mm circles
-1 of the 15 mm holes
-30 mm hole
I am new to inventor but I would also like to be able to set up my constraints correctly. I'm also not sure if my sketches are ideal for this part either. I usually get an error concerning my fillets from the base to the center support beam when I try to change the 100 to 75.
Any help would be greatly appreciated.
Sketch1 is unconstrained - start here
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
and use equal (=) constraints rather than duplicate dimensions.
Sketch2 is unconstrained (and I think it was off-center, but did not double check).
Extra points in Sketch2 on circle.
Sketch3 is unconstrained.
Top arc and right side (tangent) angled line.
The arc and line overlap each other.
Tip: When creating a line tangent to an arc click the arc (I would assume at this point still a circle) and hold mouse button down dragging to next arc (Inventor will automatically add Tangent constraint).
Once you get the hang of sketching all of the needed constaints (except =, would be nice if Inventor would do that too) will automatically be added by Inventor - all you need to do is dimension.
