If we had access to the rest of the API from within VBA function called from
parameters this would be so easy...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Kent Keller" wrote in message
news:0F28B9C17DD71C980145AA11D72768DE@in.WebX.maYIadrTaRb...
> Even uglier, (note haven't tried this so it may not work) you could
probably make the
> part longer than you need, add a hole in the excess area and array it,
then extrude cut
> off the original hole and the excess part. In the array qty you should be
able to have a
> parameter set up to reduce the qty in the array if the part gets short
enough.
> If this is too whacked, then my excuse is I haven't had my coffee yet. 8^)
> Kent
> Assistant Moderator
> Autodesk Discussion Forum Moderator Program
> "RuiF" wrote in message
> news:8CF4DA3C1A36D45BC564E8D470909D3A@in.WebX.maYIadrTaRb...
> > An extruded feature will give you the "didn't change number of faces"
error, but it's
> still ugly.
