I have the same problem, good thing this job is by the hour, I'm making a killing doing sweet piss all. Thanks Inventor should I send you your cut?
Hi userforums,
What pack and go options do you have selected, such as Skip Styles, Skip Libraries, etc.
It might be that using one of these options could help. If you provide a screen shot of the pack and go dialogue box, with some further details about whether you need to collect styles, libraries, etc. it might help.
If you're not sure what some of the options do, this link might help:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-B25088E2-AF91-4774-A168-C141F6147AD8
I hope this helps.
Curtis
It takes more than 5 minutes to pop up the dialogue box so I can select what I want to pack and go.
Hi Patrickwesc,
That does sound like a problem. Do you have any information with which others could work to help you resolve it? Maybe some information about your OS, your Inventor version, how your file structure is set up, antivirus programs that might be running, does it do that with all Inventor projects (*.ipj) or just one?, what have you tried so far?, etc.
I hope this helps.
Curtis
Inventor 2014 SP1
Intel Xeon E5-1620 3.7 GHZ
16 GB DDR3
240 GB SSD, Sata AHCI Controller
Nvidia Quadro K5000
Space Pilot PRo
If you want to blame this on computers maybe inventor should quit pretending like the software runs on this:
Windows® 7 (32-bit minimum, 64-bit recommended) or Windows® 8 64-bit[1]operating system
Oh look I only need to spend a thousand bucks on a laptop and I can run inventor!! How wonderful!!
This is a joke too. I don't see anything about ram speed or hard drive speed.
64-bit Windows 7 or Windows 8[1]
Hi Patrickwesc,
Just to clarify, are you saying that if you right-click on an asssembly file from within Windows Explorer and choose Pack and Go, that it takes 5 minutes for the pack and go dialog to come up?
or
Are you saying that the dialog comes up fine, but when you click the Search Now button to find the referenced files that it takes 5 minutes?
If you're seeing the lag when you click the Search Now button I have a hunch about what is going on. It could be that your assembly file is missing one or more references to a file(s) and is taking forever to index your project directory due to a setting in your project file. I just set up a test senario and was able to observe pack and go taking close to 10 minutes when I attempted to Search Now on an assembly file with a known missing reference.
So as a test, I would suggest closing all of your Inventor files and then going to the Get Started tab and clicing the Projects button. In the Projects editor, look in the bottom pane and expand the Options pane:
Then right click on the Using Unique Filenames setting and set it to No. Then save the changes and exit the Project editor, and then try to do a pack and go again.
If this helps things post back and I can explain why. If not, then a bit more detail about what's going on would be helpful.
I hope this helps.
Curtis
