Inventor General Discussion
New Member
paul
Message 1 of 5 (1,544 Views)
PDF to DWG to Scalable Inventor 2013 Sketch - Spline Control Vertice Issue
1544 Views, 4 Replies
08-09-2012 05:14 AM
I have a client who is replacing a large fleet of machines located in premises throughout the country. In theory the replacement program should be straightforward..... however machine dimensions have increased slightly, new service access doors have been added and user control switches and indicators have moved. I have Inventor Assemblies of the machines to show the door and body changes, but not the complex user interface panel (buttons and switches). If I could only import a sketch of the interface panel, it would look great in an Inventor drawing and I could dimension the all important position of components on the interface panel.
I have PDF drawings of the fascia panels which I can import to Adobe Illustrator and save as a DWG. When I look at the DWG in AutoCAD Mechanical, all looks well. When I import the drawing to Inventor part sketch however lots of spline control vertices appear. I cant delete the control vertices in AutoCAD or the drawing falls to pieces when imported to Inventor.
How then do I hide the vertices from my sketch in Inventor. Am I doing things the hard way? Are there shortcuts to importing PDFs in Inventor?
Inventor 2013 sketch mode is excellent as I only have to change one dimension to scale my sketch. I can also stretch/manipulate the sketch to make up for any errors in the original PDF.
Valued Mentor
mpatchus
Message 2 of 5 (1,541 Views)
Re: PDF to DWG to Scalable Inventor 2013 Sketch - Spline Control Vertice Issue
08-09-2012 05:27 AM in reply to: paul
You could save the pdf as an image file (jpg, png, gif, etc) and use it as a decal on the Inventor parts as an alternative workflow.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
New Member
paul
Message 3 of 5 (1,515 Views)
08-13-2012 03:36 AM in reply to: paul
Thanks for your email. I ended up scaling and simplifying the drawing in Illustrator. Inventor just didn't like the dwg files I was bringing in; everything kind of ground to a halt. The splines don't show in the Inventor drawing but they sure seemed to affect performance. Cheers, Paul
New Member
philipjs
Message 4 of 5 (1,425 Views)
11-15-2012 07:29 AM in reply to: paul
I usually use Adobe Illustrator and Any PDF to DWG Converter. Adobe Illustrator is a powerful application that can convert PDF to DWG, Any PDF to DWG Converter convert PDF to DWG/DXF in batch mode.
New Member
michael_lando
Message 5 of 5 (1,327 Views)
12-12-2012 12:12 AM in reply to: paul
I have used Aide PDF to DXF Converter and it works fine. It converts vector pdf drawings into the CAD format. If the PDF is raster based, the software will create an drawing but not 100% editable.
