I have a problem on inventor 12:
When i export a file abc.idw in pdf, the file abc.pdf can't be print.
i think it's a restriction problem but there is no restriction on inventor. So i think the problem come from pdf creator (wich is install on my computer too).
i have surch few hours but i don't find anything.
Do you have a idea?
Think you.
Try printing abc.idw to PDF Creator instead of exporting. Does this work?
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
PDF Creator is a Print-Driver that creates a PDF without any layers. Use it just like a printer. The Export to PDF within Inventor is a file creation that is not using PDF Creator, but is using Inventor with Adobe code to create a PDF file with layers and possible a newer version PDF than what is created with PDF Creator.
