hI all im stuck, i dont know how to use or find the PCD function plz help. All i have is a base however i need to make holes with 90 degrees on a 100 PCD
Solved by PhilSaw. Go to Solution.
You need to use the pattern function.
In that you can do a rectangular or circular array.
