Solved by pauldoubet. Go to Solution.
Anyone know if this is possible now? I did the work around but this would be cleaner.
Not sure if this is a new feature or not, but when you right-click on a table there is a "Table>Split Table" option. It splits the table wherever you right-clicked and you can put the split wherever you want. There's also "Table>Unsplit Table" if you decide you want to reassemble.
I know this post is ancient but it was the first one to pop up when I searched for the same issue.
Hi
The thread was to place a blank space between the split tables.
There is no solution for this yet. I never thought of the suggested workaround, I personally add a blank column and change the width, but it does not look the best, but it's all we have at the moment.
This might be a good one for the Ideas Forum, if it's not already in there. I marked the workaround as a solution for now so others can find it.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
