I'm looking for a solution to place the overall model dimensions in the title block.
We have a box (Promted entry) in our company title block were we manually typ our overall dimension of a part (or in some cases assembly).
For our planning engineer this is easy because he can easy see the dimensions of the "base material" or the size of a container / box in case of an assembly.
The risk that sometimes people forget to change these dimension when the model is changes.
Now I'm looking for a solution (e.g. VBA / iLogic) to place the overall dimensions Automatically in the title block.
The overall dimensions are available in the "BIM Exchange" menu > Check Design. Maybe these dimensions can be used.
We're using Inventor 2014.
You should be able to pull the LENGTH, WIDTH & HEIGHT dimensions from the model into the drawing iProperties, which then can be used in your title block.
Suggestions
Obviously you would want to do all of this in your IDW template.
@ Matt
This could be an easy (possible) option indeed.
It's a structural change in work method.
The H W & L dimensions aren't added to the drawing, they are part of the model.
I'll try and do some screen caps later on my other computer and post them here. For some reason I can't post photos from this computer now, since IT decided to reimage my box. 😞
