Inventor General Discussion
Valued Contributor
michael.marx
Message 1 of 7 (615 Views)
Output step tolerance
615 Views, 6 Replies
10-04-2010 06:49 AM
Is there a way to define the export tolerance of a step file?
Now the tolerance is always set to 0.01mm but i need a tolerance of 0.001 to go further in another CAD/CAM System.
mima
harco
Message 2 of 7 (611 Views)
Re: Output step tolerance
10-04-2010 07:41 AM in reply to: michael.marx
Possibly set in document settings> units, set the precision 0.0000.... not sure though.
Give it a try, see if it does what you want.
Valued Contributor
michael.marx
Message 3 of 7 (604 Views)
10-04-2010 08:03 AM in reply to: harco
sorry thats not what i want. This is only the viewing tolerance of dimensions not the geometric tolerance
mima
Employee
ToniQin
Message 4 of 7 (540 Views)
10-14-2010 10:54 AM in reply to: michael.marx
Hi Michael,
Inventor STEP export translator doesn't support customer tolerance. I am sorry that you are not able to control the accuracy for the STEP files.
You may have known that with tighter tolerance, your STEP file size would grow bigger. There are some tread off between accuracy and data size.
Please contact me at toni.qin@autodesk.com if you would talk about this more. We would be very happy to hear your opinions.
Toni Qin
Employee
smadhanraj
Message 5 of 7 (533 Views)
10-14-2010 11:05 AM in reply to: michael.marx
Hi Michael,
0.01mm is the default export tolerance used during STEP/IGES export. We will consider making this export tolerance as an user controlled value in a future release. Feel free to send the file to madhanrajDOTselvarajATautodeskDOTcom (if you can) and we will investigate if there is any issue with 0.01mm fit tolerance.
Madhan
New Member
Designboltz
Message 6 of 7 (232 Views)
11-07-2012 09:17 AM in reply to: smadhanraj
Is this the only tolerance available?  Even for Parasolid export.
Spoiler
Employee
ToniQin
Message 7 of 7 (225 Views)
11-07-2012 09:56 AM in reply to: Designboltz
For export to Parasolid, there is no option for tolerance. If you have further questions, please send me email to toni.qin@autodesk.com
Toni Qin
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
