Through the process of adding/changing a model the idw gets clobbered and most/all of the text that was on the drawing goes away. It would be nice if it just went magenta and let me re-attach the text. Enough now, the problem is the origin indicator is now not visible. I added dimensions and I need to change the reference elevation. If I can't find the origin indicator to select it and right click and change it. And yes when I right click on the new dimension it shows that the origin indicator is visible.
