Resurrecting an old post here but the last post (the work around) is a bit unacceptable as far as I'm concerned.
I've got an example where we are dimensioning from a hard edge to the intersection of a hard edge and a centerline. How do we add an ordinate dimension to this situation? Again, adding a sketch for this is not acceptable in my book.
Has this been added? Is it available in 2012? If so, we're unable to find it.
Here's what I need to dimension to:
Hi CelticDesignServices,
First, let me be so bold as to question whether that hole would really be angled in what appears to be a sheet metal part. My thought being that it would be placed in the flat and would not be at that angle.
But assuming that it is drilled at an angle, try this:
I hope this helps.
Curtis
Thanks Curtis.
Actually the pic I supplied is not an actual part, I was just playing around with the Sheet Metal Bend tables and had that "dummy" part open at the time this question came up from a co-worker. Thus is quickly extruded a hole at an angle to demonstrate the inability to dimension to the intersection of an edge and a CL.
Sorry for the confusion.
As far as your work-around, it should work, but dang.....why can't Inventor do something like this in the dimension command, it seems fairly simple and obvious.
Hello? AutoDesk? Are you listening?
It dawned on me after I posted earlier that we can just use the centerline end point to place the dimension and then drag and drop the dimension snap to the intersection point after the dimension is placed, as well. Although to do so you have to "scrub over" the lines in a particular order to get it to snap to the correct place.
I hope this helps.
Curtis
Edit:
I just noticed you've already commented on that solution in another thread:
http://forums.autodesk.com/t5/Autodesk-Inventor/Oridanate-dimension-problem/td-p/597031
