Steve Walton
So did you find out how you can change the default setting so that you can orbit with the mouse wheel as it is much easier than f4 button. thanks
On my system, if I hold "shift" and hold the scroll wheel down it will orbit the model. I use a Spaceball though.
@mikevick wrote:So did you find out how you can change the default setting so that you can orbit with the mouse wheel as it is much easier than f4 button. thanks
What version of Inventor are you using? Works here on 2011.
as others have mentioned, this varies per mouse.
If it's a MS mouse the defaults are different than say logitech. If I recall, we have a couple of MS mice here, that were defaulted as you describe. Just go to the control panel and Mouse settings and have a look. Also you might post back with the model mouse you have and someone who has that one can look at their settings.
@mikevick wrote:2009 it just pans and i cant find the settings for it
I don't think this was added until 2010.
I recommend you purchase a 3D Connexion Space Navigator anyhow. Best $59 investment for CAD you can make.
I have a standard dell mouse. Any idea what i should change the settings of the roller button to? Is there a point buying the mouse if i cant get that button to work? thanks for your speedy replies too
@mikevick wrote:Is there a point buying the mouse if i cant get that button to work?
Not sure if this question is in reference to the 3D Connexion Space Navigator.
The Navigator is not a mouse - you use in you left hand to zoom, rotate, pan and use your mouse in right hand to left pick, right click context menus......
The Navigator will zoom, pan, and rotate all in the same motion - it is very much like holding the part or assembly in your hand. In fact I observe users constantly rotating their model with the Navigator while they are working or simply thinking as it gives a sense of 3D space.
Indispensable for filleting and Routed Systems in particular.
At AU Cob Rohee kept referring to "gratuitous" rotating in his presentation, but I have observed that it really helps in the design process to have the model constantly shifted around. What is it we tell a very young kid when observing some precious artifact - look, but don't touch. But they want to touch, hold, manipulate the object to understand the object. That is what these 3D Connnexion devices do for us as designers.
http://www.3dconnexion.com/products/spacenavigator.html
Oh, it also works great with Google Earth. Before I go to any new city I "fly" through the streets on my intended route so that when I arrive I already know my way around.
I don't like the default settings (particularly for Pan/Zoom) so experiment with different settings.
Have you tried setting the mouse wheel button press to "MIddle Button". If I remember right, that did the trick for us.
When I first took this job, my background having been mainly 2D, I foolishly resisted the offered Space Explorer. Now after having it trustily at my side to the left of my keyboard the last 3 years, I don't know how I ever got along without it.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I used to give all the"Space-Ballers" on this forum a bad time. I tried a 3D mouse about seven years ago and will never go back.
They can pry my 3D mouse from my cold dead hand.
So i got rid of the old dell mouse and replaced it with a wireless laser mouse 8000 microsoft. and i changed the settings to middle click in the control panel but im still getting pan when i press the middle button 😞
I apologize if you've tried this as you've mentioned it above but, is it safe to assume you've tried holding down the shift key while you do this? I've checked several of our computers that don't have a 3D controller and the mouse wheel click is set to "Middle Button" and holding that + shift will orbit the model no matter what make and model of mouse.
If you've done this and it still doesn't work... well.. I'm tapping out. You'll need someone smarter than me (which shouldn't be hard to find).
I must add though the earliest version we have loaded is 2010.
@mikevick wrote:and i changed the settings to middle click in the control panel but im still getting pan when i press the middle button 😞
01/20/2011 JD Mather wrote,
I don't think this was added until 2010. (Shift hold wheel ).
I sometimes think some of you guys must be on the pay roll at 3D Connexion
Jokes aside - I have been using Inventor for around 5 years now. Love the software.
I recently had to use Solidworks for some university work and absolutely loved the orbit with wheel mouse.
I purchased a Space Navigator 3 or so years ago and it sits dormant on my desk - I just cannot get used to using it, and when I do have a crack it slows me down so much, so I just revert back to the old F4.
Not for a minute knocking the Space Navigator - would love some tips on how to get used to the darn thing, tutorials etc?
Regards.
It's like any of the "technological" advances in my opinion (the Ribbon comes to mind). At first I can't believe I took the plunge. I force myself to do it. A few months later I can't believe I ever did it the old way.
I was forced to give a presentation at a clients office where I didn't have my 3D mouse the other day. I couldn't do it! I looked like such an idiot !
One of them asked me at one point: "can we see this from the other angle" and my direct response was "probably... give me about 5 minutes and I'll see if I can get it over there". They laughed and then spent 15 minutes asking me about a 3D mouse and how it works. Maybe I should work for 3D Connexion on the side.
Oh.. I forgot. I actually played the puzzle game that came with mine for a few minutes each day while I was learning it. Also, getting familiar with the settings and what they do was really helpful to me as well. Good Luck!
