Hello all,
It is possible to generate the model of only one sprocket, without drawing the whole transmission?
If possible, how to generate this model.
thank you
Solved by venicio. Go to Solution.
With the Design Accelerator? No.
Create both - use only the one you want.
or
Create an iPart.
@Venicio wrote:Hello all,
thank you
Well you sort of can. You will still see a "ghost" sprocket besides the one you are interested in and a blue ghost chain too (though it looks more like a belt). Just set one of the sprockets as "Virtual".
