Inventor Forum
Only can cut extrude part sketch in assembly
1 REPLY 1
ashal7
13385 Views, 1 Reply
I tried to makes a new part in an assembly by making a new sketch.  The plane of this sketch is in one of the existing part. However, after I finish of making the sketch, I only can cut extrude it and the other function button are unable to use. What I did wrong? I need to join extrude the sketch to make a new part.
1 REPLY 1
IgorMir
in reply to: ashal7
Those features are for modifying the model on an assembly level - not for creating a new part. To create a new part from within assembly you have to select "Create Component" first and then proceed with the modeling.
Igor.
Web: www.meqc.com.au
