Inventor actually provides 2 solutions to an ellipse offset scenario.
1. If you pick the parent ellipse at or near a quadrant, the result is an
ellipse.This has no limit on offset-ability but the fact remains that 2
ellipses cannot be considered true equidistant offsets at all distances. To
see this, drag the offset to its minimum (flat) and see that its visually
not a true offset. These results cannot be converted to splines with a RMB
option after creation.
2. If you pick the parent ellipse approximately midway between quadrants
(like north east), the result is a true offset which is not truly elliptical
(will have sharp points). This offset has a minimum limitation where the
offset would become invalid. These can be converted to splines with a RMB
option aftercreation.
- drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Toll Free: 1-(866) 698-2831, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
"Dave Hoder" wrote in message
news:C99AD326DF8434935838DAEF8322C000@in.WebX.maYIadrTaRb...
> Thanks Pat, where can I find more info on this? More & more customers are
> requesting elliptical and organic shaped products. Why isn't an offset
> ellipse just a smaller ellipse?
> Dave Hoder
> Product Design Engineer
> idX Seattle
> www.idxcorporation.com
