Inventor Forum
OUT-OF-DATE FRAME MEMBERS
3 REPLIES 3
cadlad
532 Views, 3 Replies
Highlighted below are members of a frame generated assembly that refuses to update when its sketch is altered. The assembly, frame, skeleton, and members are all checked out of Vault. I have performed a Rebuild and Regenerate Members. It just won’t update. 😞Untitled.bmp
Dell Precision T3610 - Windows 7 SP1, 64x, 16GB RAM, NVIDIA Quadro K4000 (driver 9.18.13.5306), Inventor 2013 SP2 Update 6 - *Autodesk Inventor Professional Certified*, AutoCAD 2014 SP1, Vault Professional 2014 SP1, 3DConnexion SpaceNavigator
3 REPLIES 3
cadlad
in reply to: cadlad
Isn't this always how it works? Create a post. Fiddle some more. Get it to work. 😛
I am toying with some options and had therefore created an LOD for the frame in the frame generated assembly. It chose to update the frame once I switched the LOD to Master.
wimann
in reply to: cadlad
Glad you posted the answer. I read your post and was kind of stumped.
-Will Mann
Inventor Professional 2020
Vault Professional 2020
AutoCAD Mechanical 2020
bobc
in reply to: cadlad
I'm having a similar problem. I started out with a 10" x 10" frame, added some U-Shape channels, then changed the sketch to a 5" x 5". The channels don't resize. See attachment.
I did what cadlad did (created an LOD - there was already a Master LOD), then Activated the new LOD, then re-activated the Master. I saved my assembly, closed Inventor then re-opened it - no resize.
Any ideas?
--Bob
AutoDesk PDS 2014
Windows8 64bit / Asus P9X79 / i7 3820 / 32GB RAM / 256 GB SSD / nVidia K2000D / Dual 27" LCD
