I'm trying to constrain a length of ACME threaded rod to a nut so that when the rod is spun or threaded it shows it traveling into the nut as it will be grounded. I would like it to work as a driven assembly or if I was to turn or spin the rod by the mouse. I've reseached this for the last 2 days and can not spend any more time on it so time to ask the experts. Any help is greatly appricated.
Solved by pcrawley. Go to Solution.
Solved by CCarreiras. Go to Solution.
Have a look through this post - it's the same theory.
