Inventor Forum
Nut and bolt constrainted to allow/show motion
4 REPLIES 4
gordon.rogers
930 Views, 4 Replies
I'm trying to constrain a length of ACME threaded rod to a nut so that when the rod is spun or threaded it shows it traveling into the nut as it will be grounded. I would like it to work as a driven assembly or if I was to turn or spin the rod by the mouse. I've reseached this for the last 2 days and can not spend any more time on it so time to ask the experts. Any help is greatly appricated.
4 REPLIES 4
Also I'm running IV2013 and do not have dynamic simulation.
CCarreiras
in reply to: gordon.rogers
Hi!
Faces tangent between parts. Drive the angle constrain.
Test it. Files in attach.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CCarreiras
pcrawley
gordon.rogers
in reply to: pcrawley
Both of these work but the first gets an error after too many revolutions. Not sure what causes it.
