Inventor Forum
Nothing in Design tab HELP!!!!!
11 REPLIES 11
Message 1 of 12
ComputerGuru666
1140 Views, 11 Replies
I have 15 CAD users all using PC's almost identical in spec all connected to a windows domain using Windows 7 pro sp1 64 bit & Inventor 2014 pro. The problem is I have one (1) user that no matter what computer he logs onto his "Design" tab in Inventor with the "Bolted Connections, Frame Generator, Power Transmission, Spring Generator, etc" is completely empty (All 14 other users do not have this problem) and some of his standard hot keys like "Ctrl + ]"  (turns work planes on and off) do not work either (the hot key issue has been a problem for him since Inventor 2012). The only thing I can think of is that it has something to do with his User Profile but before I go completely deleting his entire user profile off the Windows Small Business 2011 server and recreating it does anyone know what might be causing this and how to fix it?
Thank you
Computer Specs:
Windows 7 (64 Bit) Pro. SP1, Inventor 2014 Pro, 3D Connexion SpaceNavigator (Driver 3.15.2)
Motherboard: ASUS Rampage IV Extreme x79 Socket 2011
Processor: Intel Core i7 Six Core Sandy Bridge-E 3.2GHz OCed to 4.7GHz (Under Water)
RAM: G.Skill Ripjaw Z-Series 32 gig quad channel of RAM 1800MHz OCed to 2133MHz
Video Card: 2x Nvidia Geforce GTX 770 (Running Six (6) Monitors)
Monitors: [Primary = 2x 24in HD WS][Secondary = 2x 22in HD WS][Tertiary = 2x 19in FS]
Primary Hard Drive: OCZ Vertex IV 256 GB Solid State Drive
Secondary Hard Drive: OCZ Vertex III 120 GB Solid State Drive
11 REPLIES 11
Message 2 of 12
Cadmanto
in reply to: ComputerGuru666
Go to "Tools>Add-in"  and see if what is shown below is turned on.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 12
in reply to: Cadmanto
I would greatly appreciate it if you could help me please. I have a similar problem, this all started when my company changed their servers to another location. Now, the Design Tab does not work (please reference the pictures).
I re-installed inventor, but that has not improved anything. Even the autodesk experts here in Chile have not been able to solve this problem, please help!
Jaime from chile
Message 4 of 12
All Content Center does not work
Message 5 of 12
Cadmanto
What does your folder structure look like in the master project file?
Do you see anything here?
Best Regards,
Scott McFadden
Message 6 of 12
And, I cannot see anything, when I touch, place from content center.
Message 7 of 12
works fine when I start with another user who has no problem, maybe is not the inventor, maybe are the user permissions of the network
Message 8 of 12
Cadmanto
Your screen shows your CC is on your local yet you mention a network.  Is the other user using a CC on the network?
I would compare his settings to yours to see what the difference is.
Best Regards,
Scott McFadden
Message 9 of 12
All the user have the CC in theirs PC
The settings are the same.
Message 10 of 12
Cadmanto
I also noticed that you had three custom project files.  Do they deam different results?
I hate to say this, but I know a few months back there was a few in my department that had this same issue
with their CC (including myself) and what ended up happening was Inventor along with all the Autodesk products needed to be reinstalled.
Best Regards,
Scott McFadden
Message 11 of 12
I'll do the last test before reinstalling. Repairing user permissions, then, I will inform you the results.
Message 12 of 12
Cinetrak
I was looking in the wrong place. The design tab and it's contents appear when working on assemblies, but not on parts.
